TOYAN Engine FS-S100AT Transparent Version - 5th Anniversary Edition
After five years development, Toyan has made new progress in the engine model area and it is now launching its 5th Anniversary Edition, the model number is FS-S100AT, this model uses an observable combustion chamber design, with a new adjustable carburetor and ignition angle flywheel. Due to the use of a central camshaft design, the engine height can be refused to the extreme.
1. Can observe combustion chamber inside engine
2, The central camshaft design makes it an extremely compact 4 stroke engine model
3, Newly designed adjustable carburetor system
4, Adjustable Ignition Angle flywheel
5, High efficiency cooling fan
