Old 06-11-2020, 06:05 AM
guapoman2000
guapoman2000's Avatar
Yes, Throttle trim has nothing to do about success criteria of Binding any Transmitter to Receiver. It will still Bind and Throttle Trim has everything to do with being able to Arm the Throttle later when you have the model all active and the motor will not arm due to Throttle Trim not in Null (OFF).
You didn't specify which Receiver you are trying to use?
All my Receivers in the Spectrum Bandwith are Spektrum brand. They are pretty much straight forward as I do as follows:
1. Install the Bind U-Cable in the appropriate input at the Receiver.
2. Connect "a" battery to the ESC power input.
3. While following my specific Tansmitter (DX7, first Generation), I turn ON the Transmitter in Bind mode.
Hope this helps!
