I learned this on my F-14 the stab mounts were stupid and not safe, using light ply for servo mounting makes you wonder what they are thinking. So when I did my f-18 like this I knew from the get go it had to be done. Plus you need to make sure you make the bearing on the servo arm parallel to the shaft of the stab don’t trust the mount angle in the fuse, they can be off a lot.
