Old 06-21-2020, 07:22 AM
  #526
n8622t
My Feedback: (8)
Originally Posted by husafreak View Post
Thanks, that Tru Turn Spitfire spinner does look good. I saw a smaller Spitfire spinner from Top RC that looked right but too small. 5 1/2" is good size too but I'll probably be cutting the cowling back a bit then for scale fidelity and cooling. They are pricey though! And they are selling a part for using it with the Moki which will add even more. Unless I can find someone to machine a transition from 4mm to the Tru Turn bolt size. I think its 10/32. I like that the Tru Turn blade cutouts can be done for my prop no extra charge, it is a German SEP prop, wood, with a very wide blade. N8622t your cowl/spinner looks terrific!
just a tip on the cowl opening...before you cut at your mark, glue in your reinforcement support because the cowl turns into a bowl of jello after cutting the nose ring out. Itíll save you a lot of work
husafreak (06-21-2020)
