RCU Forums - View Single Post - adding flaps to an arf
Thread
06-23-2020, 12:05 AM
133
bigtim
My Feedback: (
13
Last night I cloned the formers from a TF P-51B conversion kit I have, if any one wants to do this the TF kit is nearly identical to the Hangar 9 in size.
so I used a 3/32 piece of sheeting as a base for the formersand after cutting them out on my mini Dremmel scroll saw, I did leave out the notching on the bottom so I had a flat surface drew a center line on the former and sheeting and using the TF plans to get distance right glued it up I’m surprised it fits so well I did have to add a tiny spacer at the fuse formers to lift it up into position it did require some trimming to get it into the right position, I also added some wood to the rudder V stab so it has a little more scale and strength before I sheet it I am also going to use Robart hinge pointe So I’ll put some balsa blocks in as hard points
12:17 AM
Reply
Like
bigtim
View Public Profile
Send a private message to bigtim
Find More Posts by bigtim
View iTrader Profile
