Originally Posted by
DUCMOZ
# 1 cause of flame out in turbines is fuel supply and air in the fuel lines. make sure your air trap does what it should.
The fuel system in these new smaller motors like the X45 is so small its easy to clog things so proper fuel filtering is important before it goes in the tank. 2nd people should also make a habit of cleaning the fuel tank with fuel and discarding it once clean when you build the model. This doesnt mean add more filters one filter in the system is plenty, one pump on the suction side between pump and tank or if you have to use a UAT then filter between UAT and pump. All UATs are essentially filters so keep that in mind as well and even consider putting something on the vent if possible. Probably the biggest reason for trash in the tank is sucking through the vent and do feel bad about over sizing your vent system.
