RCU Forums - View Single Post - Design KI1603 X-WRAE
Thread
07-05-2020, 02:46 PM
56
H5606
A 1/32" ply side mount for the throttle servo was abandoned in favor of a tray as the front fuse side separation points don't allow flat areas for bonding - fabricated from 1/16th ply with 1/8" lite-ply doublers for more screw bite - predicted nose-heaviness allows aft-most positioning of throttle servo -
Located tank feed line hole in fuse bottom sheeting and vent hole in firewall; fabricated a custom foam cradle to position and immobilize tank; added a tape pull tab to facilitate tank removal - clearance for tank vent blister was added to top of hole on former, F-2 -
I've never used exhaust throttle on Cox engines before - installation presented numerous challenges to get it working satisfactorily - ended up using a braided cable (not pictured) with .047" Z-bent wire soldered to end attaching to throttle snap-ring.
Final coat of epoxy resin to tank compartment and sealed up fwd fuse with top sheeting, opened up hole for choke tube, and sanded excess sheeting flush -
Unused servo mount -
Substitute servo tray -
Throttle servo in mount with tri-stock gussets -
Intended throttle servo location at aft end of fwd fuse -
Fuel tank cradle fashioned from Ethafoam on bandsaw -
Tank in cradle -
Tank in position; note vent line poking through firewall -
Fuel tank access pull-tab -
WOT?
Throttle cut? (I hope) -
Shimming the throttle sleeve to eliminate slop w/ 4 layers of copper tape -
X-Acto knife used to trim out center of shims -
Throttle linkage installation -
Front end before rounding off all corners -
Throttle servo tentative position -
Notch filed in former for tank blister clearance -
Reply
Like
mgnostic
(07-06-2020)
H5606
View Public Profile
Send a private message to H5606
Find More Posts by H5606
View iTrader Profile
