Originally Posted by
camss69
I’m really interested in how this setup works for you. I have dual Fromeco (not Jeti) 2600 LiIon packs in my T-1 Mini. I’m running Savox 1260 Mini Servos and a Jeti Assist 12 channel receiver. After the 3rd flight with the gyro on they pull the voltage down so that my low voltage alarm (set at 6.8v) starts going off. By the 4th flight it goes off quite a bit. This is during flight when the gyro is working.
In my F-86 with 11 servos/valves and igyro 1e on ailerons, I run twin Jeti 2600mah through a Powerbox Gemini regulator, and fly all day on the original charge
