RCU Forums - View Single Post - The new Tornado sport jet
Old 07-09-2020, 11:11 AM
  #3651
john491
My Feedback: (13)
If it is balanced properly you do not need any elevator trim, except with the flaps. The elevator is trimmed when a straight edge across the TOP surface of the elevator is flush. A bit of down thrust on the turbine as well, about 3-5 degrees. The usually accepted CG is about 13 in. from the leading edge at the fuse.
John
