Grease is used to seal the drive shaft tube so, if there isn't enough, you may take on water when going at slow speeds.
If the boat uses a flex cable drive, it will shrink in length under load. If that's what's happening, you're probably overheating the ESC, resulting in the crawling back to shore.
