Aghhh cheers for he reply bud. So I need to take out the drive chain and lubricate it? I knew that the instructions said I had to do this after 30 minutes of run time and I have bought the horizon marine grease. What’s the flex cable drive?
QUOTE=Hydro Junkie;12619267]Grease is used to seal the drive shaft tube so, if there isn't enough, you may take on water when going at slow speeds.
If the boat uses a flex cable drive, it will shrink in length under load. If that's what's happening, you're probably overheating the ESC, resulting in the crawling back to shore.[/QUOTE]
