Originally Posted by
jsnipes
I have found cross control trims to be very useful ... e.g. you can fly with your right hand while easily trimming with left hand on the left side trims. Just be careful when you first start using it so you’re trimming what you think. You’re trimming!
I do not use a rudder trim ... composite jets should never need it (Except perhaps thrust vectoring) and I use the right side L/R Trims for steering. I do not use the up/down on right side ... I use on/off locking switch for turbine on/off.
JS
I'm planing to set up my radio the same way ( all I know about setting up a radio is out the door ) I want to give X-triming a go.
