Originally Posted by
Pylonracr
Correct. I kind of thought that would be fairly self explanatory since I said that you weld a small blob where the fitting goes. Apparently I was not concise enough??
You weld a small blob where the fitting goes, file the top of it flat, drill and tap it. A drop of red loctite keeps the fitting from coming out.
Scott
Scott, if it was just me you were communicating with, your post would have been fine. The issue is when people that have never worked on our "toys" are involved. My post was mostly for them so, if it elicited confusion, you have my apologies.
