Originally Posted by
tedsander
J.........................
So, if making a change using the Simulator: one must close the Simulator, then close the file in Companion, and re-open it in Companion to see the changes there.
Vice versa, if making a change in Companion: one must save the file, then close and start up the Simulator again to see the changes.
The version of the Simulator inside Companion allows you to make changes while using it, but they are NOT saved when the Simulator is closed..........................
Ted,
My apologies for the very late reply. However, I did try my installed separate simulator and found exactly the same irregular and inconsistent behavior, so I quickly went back to using the "main" Companion Simulator.
I get by now with it by repeating the "reload radio data" as many times as required to get it to boot into operation and reflect the actual loaded transmitter data.
It works this way.
Besides, the above saving procedures might be enough to cross up an old bloke like me one early morning and so lose some important data (again)!
Better to be safe than sorry.
Thanks for the detailed explanation.
Jim.
