Old 08-05-2020, 12:12 PM
  #47133
the Wasp
Originally Posted by rowdog_14 View Post
Glowgeek Thanks for the suggestion. That still did not work so I decided to pull the engine apart and saw the cam was damaged probably causing it to no turn true. If you see the end of the cam of broken off. Which in turn was probably causing the intake valve to not function properly. Does not seem like any other damage was done but will fully break it down just in case.
dang !!
what are you going to do now ?? does Horizon have a new cam ??
Jim
