This is how I have my Throttle Idle and Throttle Cut set. This works on JetCat, Jet Central, Wren, and all versions of KingTech. Be sure to go through the "Learn" process AFTER setting this up using the chosen switch instead of the trim buttons (I use switch up for high trim and switch down for low trim).
