I've been drawing this model based on some photos I found online and the fuse is mostly done, however the wing is a bit of a mystery. I've got a few questions someone might be able to help answer so I can finish it:
1. What is the main wing incidence? Measured from the drawing I get ~3 deg relative to the bottom of the fuse.
2. What is the horizontal stab incidence? Measured from the drawing I get 0 deg relative to the bottom of the fuse. There were issues with the first kits needing lots of up elevator which is the same as the one pictured, How was this corrected?
3. What aerofoil is used for the main wing? It looks almost semi-symmetrical to me?
4. Is there any washout on the main wing?
