Thread: Stinger drive
Old 08-12-2020, 03:10 PM
billydean676
Originally Posted by Hydro Junkie View Post
A stinger drive is basically a tube within a tube and a mounting flange. All you need to do is drill a hole in the back of each sponson, line up the stinger with the hole and run your flex cable tube to that hole. Pretty much all there is to it. One thing you may want to look at is where your water line will be. To keep water out of the hull, it's best to have the inboard end of the tube above the water line OR have the tube stuffed with grease to seal it and prevent water from getting in to the boat.
Thank you, I understand the theory of it. I just wasn't sure how for out the back it should stick past the farthest point on the stern of the boat where there is overhang past where the sponson ends
