Old 08-16-2020, 06:22 AM
Outrider6
Originally Posted by sensei View Post
In the end it will come down to your prime fill preparation work that will define the outcome of your overall finish, so just take your time.
Bob
Exactly. If you have orangepeel or pinholes in your primer, then you will have the same in your finish coat(s). Make sure it is ultra clean (with denatured alcohol, acetone or lacquer thinner), and scuffed up nicely (with a Scotchbrite pad or fine sandpaper). It is all in the prep work, with anything involving chemicals.
