RCU Forums - View Single Post - Upgrading a kit
Thread: Upgrading a kit
Old 08-16-2020 | 11:46 PM
Hydro Junkie's Avatar
Hydro Junkie
The problem with a receiver that has integrated servos is that, if something fails, you have to replace the whole unit. I would go with an actual receiver, two micro- servos and an electronic speed control(ESC) with an integrated battery eliminator circuit(BEC). The other issue with your F949 radio set is it doesn't have the range of a "hobby grade" system. If it were me building this, I'd use the following:
https://www.towerhobbies.com/cgi-bin...?&I=LXXMV6&P=3
https://www.towerhobbies.com/cgi-bin...p?I=LXH291&P=3
Motor, prop and ESC determined using this information EFLDeterminingPowerRequirement.pdf
