RCU Forums - View Single Post - harbor freight neptune rc boat
Old 08-17-2020, 07:49 AM
Hydro Junkie
Hydro Junkie's Avatar
Your acquisition probably uses differential steering. That means that to turn, one motor speeds up while the other slows down. To use your DX6, you would need to use two speed controllers and either set up a mix, throttle on one stick with rudder on the other mixed to do the same thing, kind of like ailerons and rudder on a plane, or set it up for "tank steering", one stick controls one motor's speed while the second stick controls the other.
