Old 08-22-2020, 07:41 PM
  #2274
specialk1
specialk1's Avatar
Originally Posted by ScarabChris View Post
Welp....I gave the boat a run and my rigged U joint lasted a few mins then it rounded out. I wasn't surprised. The plastic on those Traxxas U joints is much softer compared to the stock AMPS U joints. No worries. I will try again. I have some metal U joints coming I will try to make work. Also I may try to do a set screw on the plastic one to hole it in place. Maybe even some JB weld to keep it secure the drive hex.
Just just a heads up. Do not use those metal u-joints that you ordered many have tried them they do not work .
