Originally Posted by
Hydro Junkie
Looks like it's time for another pair of clues
Looking for a plane:
1) This plane was developed for one thing and ended up being used for something else
2) This plane was one of the first of it's type, in more ways than one
3) This plane was so successful in it's final configuration that it beat out an ally's purpose built aircraft in the procurement process
4) This plane never saw combat but the plane it replaced did
5) One of several changes to the plane improved performance in multiple ways
6) This plane had at least three structural changes to make it capable of doing it's new task
7) One of the changes increased the length of the aircraft by several feet
8) Another change required a change in the internal framing in the bottom of the aircraft
9) The new configuration increased the crew from 4 to 13
10) This plane used tech in its original configuration that was developed during war time. One of the changes moved on to more modern tech1
11) The tech referred to in the previous clue increased the range considerably
12) A second change allowed for the carrying and use of 10 tons of payload
Good Luck
Hydro Junkie; Have we lost you? Time for an answer and/or a new clue. Thanks; Ernie P.
