I have the same motor combo with 22" props and use the Jeti Mezon Opto 95, I have also used the Castle Edge 80. Issue is availability in the US right now. I have been looking to buy an Opto 95 and cant find anyone with them in stock. Another option is the OS/Futaba 1100 but that also has an issue with availability right now.
If you are not in need of the improved vertical of the 23" props you might consider the 22", it will reduce the downline breaking.
