RE: wheel collars
The only thing the wheel collar is good for is to act as a fence for cutting the groove with the dremel. To get a perfectly cut groove, place the wheel collar on the axle so that the outer edge is at the point that you want the c-clip to be, then tighten the set screw in the collar. You now have a perfectly square fence to let the cut off wheel rest against while you cut the groove.
