Originally Posted by
jvaliensi
thank you - I actually have some of that stuff and didn't know if it will stick to the glass.
Lightly sand the area (of the fiberglass) where the glue will be applied and wipe it clean with Denatured Alcohol or Lacquer Thinner, then apply a bead of 560 about 1/8th" in diameter. You'll have lots of working time, so don't rush - just don't put too much glue on there...it will take days to dry and will squeeze out everywhere. You'll need to clamp, tape, etc. to hold certain areas in place while it dries, depending on the fit of the canopy glass to the frame. Leave it alone for at least 12 hours. Goes on white, and it's dry when it's completely clear. It's a water-based glue, so clean up excess with a wet paper towel.
