I had a bit of worry it might be TCU after having an issue with the GDT unit not turning on. After playing around big part of the day to sort it out it was only oxidation on number of connectors and the main power supply causing the problem.
All sorted out.
Problem solved after closer look into it.
Some oxidation found on number of crucial connectors, incl. GDT plug unit in pic.
