Verify the trim is set correctly, the controls on those tanks are not the best. Also check the suspension for obstructions, like hair wound around the sprocket axle, etc.
To open the tank you need to remove the tracks and there are screws under the sponsons that are a little tricky to get at but with a small screwdriver you can do it.
