Originally Posted by
GorillaToast
Came across this...
Attachment 2268415
it seems to suggest that the stab be set at 0deg and the wing set to +.5deg relative to the stab. Am I understanding that correctly?
Yes, that would be the correct setup for an IMAC or pattern aerobatic model and to a certain degree of what I use on my pattern models. The difference is that the zero stab works well with a symmetrical airfoil. Your Rearwin Speedster has a semi symmetrical airfoil that will produce more lift at the same given AOA.
