Originally Posted by
YellowAircraft
Thanks, Zeeb!
I made my own out of 1/4" Midwest ply.
Gunn,
You didn't play with the CG? Mine feels nose-heavy at the factory location...
I had it moved back a little but not much. It gets tail heavy in a hurry when going back. I think it was moved to the back of the little CG sticker they put on the side. If you add ordinance the CG moves back and needs to be redone also. I had a removable weight in the nose I could add or remove depending on if I was flying it dirty or clean. Sometimes going to do a few flights at the field its a pain to install all the ordinance so its nice to have that option.
