I CG’d last night. Looks like I needed just under 1 lb of lead to balance!
And I used Craig’s technique. It was rather easy!
I made a little stand that sits about 1 inch taller than the jet, made some plywood wing plates marked and slotted so that the stand would key into place.
All I had to do was lift the nose and rest the Hog on the stand which keyed in place on the taped plywood wing stops. No help needed and quite simple!!
