Old 11-08-2020, 07:54 AM
tedsander
He didn't specify what the electronic ignition system was, except that it was 6v. Having burned up one of mine (not at all the same engine) with over volts, I recommended the IBEC out of an abundance of caution. It may be that it can handle a LiFe without issue. Something to check with the mfg. about.
At minimum, an optical kill switch (or the IBEC) controlled by the TX is mandatory for safety.
