RE: wheel collars
I use a cotter pin for retaining the wheel. Take a torch and heat the very end of the landing gear orange hot and slowly remove heat and brush it back and forth to slow the cooling process. Use a wet rag or any thing to make a heatsink so you only anneal the last 1/4 inch or so. Then drill a hole in the gear for a small cotter pin.
