Originally Posted by
Viper1GJ
The has been much discussion about the stab mounts twisting on the stock fuse so Keith and I modified the stab mounts as follows.
6mm aluminum rod cut to 190mm
Rod had to be sanded some to fit inside the stab bearings
6mm drill bit used to drill through foam in nozzle
Areas around holes scuffed inside nozzle
Dry fit of plywood hard points inside nozzle
Hard points glued in with E6000
This mod stopped the twisting on the stab bearing in the fuse. Very stiff now.
Mods painted to match nozzle color inside and out.
Thats a great idea to reinforce the stabs!
Tone
