That motor will have plenty of power. Expect to move things around s bit. I'm thinking the servos will have to go under the wing and maybe the RX. Under the canopy will be the battery and ESC. Select a 3 cell battery that is the smallest that will give you a CG of 40% behind the LE at the root. Not having had a sailplane before, that will seem a bit far back. Mount the motor with no thrust offsets but you will need to mix in some down elevator with throttle. Trim the airplane to fly hands off with the power off. Best of luck.
