RCU Forums - View Single Post - Carburetor help
Thread: Carburetor help
Old 11-19-2020, 06:54 PM
xxkenny90xx
Originally Posted by A. J. Clark View Post
Not alot of information to go on. A couple of things to try . Take the air filter off while your trouble shooting. Does the primer bulb on the carb work? Push the primer bulb while it's running will let you know if it's running lean or rich. Check all the fuel lines and any filter. Check the clunk if it's felt. Does it have good spark at the plug.
Thanks for the reply.
The primer bulb does work. Pulled the air filter and no change. To check for spark would I just pull the plug, stick it into the wire, put it near some metal and pull the cord? I'll try playing with the primer but it's hard because it doesn't stay running long.
