Originally Posted by
jimkron
I'm trying to eliminate some nose weight as well.
From the pictures, it looks like you are flying with the CG just forward of the main wing tube. This would put you maybe 1/2" or 5/8" aft of the recommended 168mm.
Is that about right? Was your plane a little tail heavy in flight or upon landing? Or just perfect? jim
Jim,
Yes my CG is as depicted, I don't understand your last line. I don't find it overly sensitive and quite comfortable to fly.
I believe I posted my elevator throws as well. You be the judge. I suggest that you do the same as I have and start flying and removing the weight progressively as you gain confidence in the airplane and your ability to fly the airplane. I am certain I can remove more weight and will continue to study that when the summer comes again to the northern hemisphere.
Sparky
