RCU Forums - View Single Post - Carburetor help
Thread: Carburetor help
Old 11-22-2020, 07:08 PM
xxkenny90xx
Originally Posted by sport22 View Post
sounds like the engine would need to be broken in. Had the same issue with a cy230 thats old but new. the engine had to be broken in, spark plug changed, it needed a new carburetor and a good tune. make sure your flywheel is good and coil is good.
the spark plug was the biggest issue with running.
Thanks for the info. I bolted on the new carb, fuel lines, and fuel filters today and it fired right up and idled pretty good. It did start revving on its own a bit but I'm sure the new carb just needs tuned. I will go ahead and replace the spark plug regardless. One other thing I noticed is that it only runs with the choke half opened. If it's fully opened or fully closed it dies immediately. Is that normal?
