RCU Forums - View Single Post - Carburetor help
Thread: Carburetor help
Old 11-22-2020, 08:16 PM
sport22
sport22's Avatar
when the engine is cold it is normal to use choke half way open. so yes it is common for the engine to die when choke opened to soon. more or less is the spark plug causing the engine to die down. so part 1.partially clogged carburetor. problem 2 spark plug. both together was and partially is likely the same problem. replace the plug, retune the engine and let it idle for several minutes. that will work if it is only the spark plug left to replace.
