Originally Posted by
Foxbat711
Would this motor be suitable? Using 6S Lipos? What size ESC? Can you oversize the ESC?
Thanks for any support, Jim
The Rimfire .46 is probably overkill for the LT40 EG. The Rimfire .32 might be a better choice. I have the same plane powered by a Himax HC3528-1000 with 4S 5000 mah LiPOs and a Castle Creations 75 amp ESC. Prop used is a 10x7E APC. The plane flies great with more than enough power.
