Originally Posted by
jdc442
I heard it trip the gfci in my garage when I turned the power supply on with nothing on it but the dial turned up to 24v. I'm charging no more than 1c on 2 channels so about 6.5 amp each side. It does have a weird delay turning on after I turn the power switch on to the power supply. More or less it feels like the initial power up. I dunno if it matters the dial is up when I turn it on. I bought it used with my xmaxx but I think I will look into a diff charger
Is the breaker a GFCI, AFCI (arc fault), or combination breaker?
Arc fault breakers detect sparks or arcs. Switches sometimes arc when turned on and if the switch is on and you plug it into the outlet the arc at the outlet can trip the arc fault breaker.
