I usually put a restrictor in each airline an inch or two from the retract. If that is not slow enough, I add another one at the retract valve. I used to use a small plastic restrictor by Bob Dively and it only took one of them in each line, but the Robarts aren't as restrictive so it takes more to get the speed I want.
I also use a restrictor in my wheel brake airlines.
