Light system harnesses complete. I use uni-light bulk wire and crimp connectors supported by the controller in the fuse, I will probably use servo or Ashlock connectors at the wing-joint/stab-joint. I refer to each function as a zone, this jet will have four zones. All zones have their own TX logic but are activated and can be shut-off by one main switch.
Zones: - Afterburner - activated by main switch + throttle position trigger
- Navigation/Position - activated by main switch
- Anti-Collision - activated by main switch
- Landing - activated by main switch + gear is down
Note: Each LED will have a resistor to limit forward current. Attempting to put into practice
a discrete
Kirchhoff loop for each
. I have also set a LVC of 3.5v per/cell.
