Originally Posted by
Scx24JK1
where can I get what you got and not deal with axial going back and forth with this ?
send over the link of the stuff you got please I’ll just replace it ☺️ Thank you !!
hi I have the pn racing 130 70t from Kenon hobby it's about 15 dollars you'll also need the V2 transmission plate from shapeways I ordered the V 1/2 plates for more options. I also had to order a larger pinion as the shaft on motor is 2mm I have a bunch took almost two months to get. They are ten tooth. Will gladly send you one no charge. Here's my email if you'd like one.
[email protected] I can't post links yet still to new to site. But email me and ill get you all the links. My scx24 ran with the one tenth scale the weekend and those guys and gals were blown away. Hope this helps. The whole cost should be around thirty dollars. Cheers
