After run oil is injected directly thru the carb or into the exhaust port so it doesn't directly impact the o-ring. I always run the engine dry at the end of the season and then oil it well for storage.
A supply of o-rings might be had from different sources but the old school method of a fuel line sleeve over the needle valve and the shaft it threads into might be the answer to a new air seal.
