Thank you for your thorough analysis.
Originally Posted by
BMatthews
You should insert the curved wings so the curve is upwards.
At the time the photo was taken, it was likely the weight of the wings was causing this downward bend (the material used in the construction of this model is stiff paper used as a document folder cover -
the stiffness seemed quite good, but apparently the weight of the wings was stronger than this stiffness). I have a problem to check how these wings behave during flight. I'll try to connect the wingtips with a thread above the fuselage.
Overall, your remarks seem to be correct.
Why inverted V-tail? I was afraid to place such a heavy element above the fuselage and the wings. I thought that if the tail is not exactly made, the model will lose its balance. But yes, of course you are right that such a construction always causes some damage to the tail on landing.
Next time I'll do a normal V-tail.
