Question about wiring on a Traxxas Slash two-wheel drive
Does anybody know what the wire gauge is on the battery to ESC connector wire on the Traxxas Slash two-wheel drive? I know I think it's a seven c battery which would mean at the burst current would be 14 amps so I think 16 to 18 gauge or 14 to 18 gauge wire would be good enough and appropriate connector but I'm not sure can someone verify this?
Couldcould I put an appropriate size connector in series with the connectors for the battery that came with it?I already cut the wires thinking I would put the connectors in series so that when the connector wires break off the standard ones I could just take the wire off rather than take the ESC out so I'm not sure what the truck thing to do to fix it is maybe I should just solder it really solidly but I like the trip putting connectors in if I can and is anybody having suggestsuggestion
