Originally Posted by
sysiek
I’m not sure but I think that the p-200 rx has more power than the p-220 rxi
The older P200 (maybe 8-10 years ago) were indeed much stronger - not anymore though. P220RXi all the way now.... smaller, lighter, more efficient, and can charge your battery which means you no longer need those 3-4,000mAh batteries but you can do away with a 2,000mAh which weighs only 130gr. So all together, with the fuel saving one can save more than 2kg and push about the same as the P200RX.
Tassos
