Originally Posted by
Dansy
Well guy’s thing about this a secs.....the 25kg doesn’t make sense not with anything SM put out and this is 3.8m long
and with vectors, and 210 for power come on also doesn’t make any sense, I use that in my J-10 and Havoc SS.....
His jet he said was almost 100 lbs into LTM2
Most fly the XL with 210 and 300
If the model was almost 100 lbs, then in order to comply with the AMA LTMA-2 program, the maximum thrust should be limited to the model's wet weigh + 5 lbs, or 90 lbs, whichever is less.
Bob
