Originally Posted by
BoomerSooner
I’m installing a K70 G4. How’d you guys get the rear engine mount holes drilled? They sit quite a ways back for correct spacing to the pipe. Too tight of an area to get a dremel 90 degree drive in there.
I cut down a 3mm Drill bit, chuck into the 90* dremel.....does the trick, I also have some dual drill bit (not metric) those are pretty short...cut into 2 😬
